Can't play NBA 2k6 on 360 with HDTV
31 Dec 2003
Stoke on Trent
hi all,
I wonder if you could help please?
I've searched for this but can't find anything on it.
When I try to play NBA 2k6 on my Premium 360, through my Toshiba LCD HDTV (which I have set at 1080i) I get the error that I can't play it as my game doesn't support PAL-50. Please change your display setting to PAL-60.
I dont have any options for PAL settings in my Display settings on the 360 though.
what cable are you using?
What you need to do is plug the console in via COMPOSITE (single yellow plug) and change the dashboard settings to 60Hz.
Reconnect your COMPONENT or VGA cables and it'sll work :)
hi all,
Put your 360 into non hd mode, then change it to 60hz, then put it back to 1080i and it will work fine mate.
You dont even need to plug the composite in, just flick the switch on the side of the component one.
