(Solved, it works now)
Hi
I just moved my PC from its Antec 900 case to a Coolermaster Stacker 832.
Specs are:
E6600
4096MB of DDR2
GeForce 8800GTX
nForce 680i SLI
X-Fi Prelude
Raptor X
250GB WD Caviar SE
I built the PC myself in the first place; and it was working 100% solid. After the move, the motherboard light is on as usual, and pressing the power button turns on the PC. All the fans spin including on the graphics card, and the PC seems to POST. The motherboard displays LCD shows "FF" which is the code that everything is working 100%.
I just cant actually use the PC, because nothing is displayed on the screen. Tried using two different monitors and also replaced the 8800GTX with a 7600GT and it doesnt help at all.
I cleared the CMOS, now it displays "F5" which means post error, please follow onscreen instructions. Obviously I cant. (It's probably something to do with my hard drives which I will need to set in the BIOS)
Ideas?
Hi
Specs are:
E6600
4096MB of DDR2
GeForce 8800GTX
nForce 680i SLI
X-Fi Prelude
Raptor X
250GB WD Caviar SE
Ideas?
