Race Driver: Grid
Must admit I'm learning to use my new steering wheel (saitek r440) and don't actually drive, so have caused a few bumps recently, but my drivings becoming a lot smoother than using a joypad.....
PC GAMING IS HELL! :mad:
This is the first game thats tempted me back to PC gaming in years. Ive had nothing but headaches.
So ive:
1) Purchased a 8800GT OC2 gfx card
2) Downloaded the latest drivers
3) Fresh install of the demo (downloaded twice)
4) Go to run the game and im getting MAJOR pauses/stalls sometimes locking at 1-2fps according to fraps even on starting a race.
So annoyed as this is what drove me away from PC gaming, why the heck am i having these problems as many of you guys are using such settings with similar cards, someone PLEASE help im about to stick my foot into this PC.
Vista Ultimate 4 GB RAM AMD 6000 with 512MB 8800GT OC2 card
Creative soundcard set to GAME mode. 1680x1050 res, in game setting to High and Ultra.
Id suggest trying differant drivers personally...
I had some weird graphical corruption when i first tried Grid, i was using the latest Catalyst 8.4 drivers, i removed them and installed 4month old Catalyst 7.12 drivers and it ran perfectly...
I realise youre using a nVidia card but its worth a shot... Every other game i play worked fine with the latest drivers so maybe Grid is particularly hard on its drivers. :confused:
So ive:
I have a 8800gt card and an amd 5000x2 black edition cpu.
The game runs at between 50-60fps checked with fraps.
I am running my pc with windows xp and use the latest nvidia drivers 175.15.
I can not use 1680*1050 because of my monitor so i have to use 1440*900 with all game settings at max.
The only thing i can think of is the difference in operating systems.
I tried vista ultimate on my pc a while ago and beacause of loads of problems i went back to xp.
Have you tried any test programs like aquamark to see what score you get.
Drop these settings down and a lower res. I think those settings are maybe too much for your system.
I only get 40-60fps with this game at 1360x768 and you're rig looks slightly lower speced than mine.
Even at those high setting there is no way he should get 1-2fps.
I have a system nearly the same as his and at 1440*900 i am getting between 40-60fps
These are the system specs recommended by codemasters for the game.
Windows XP/Vista. (If running Windows Vista, SP1 is recommended)
DirectX 9.0c
Intel Core 2 Duo @ 2.66Ghz or Athlon X2 3800+
2GB RAM.
Graphics Card: GeForce 8800 or Radeon X1950
Sound Card: Creative Sound Blaster X-Fi Sound Card.
Dual Layer Compatible DVD-ROM Drive
12.5 GB Hard Drive Space
Mr Lattes system is better than what codemasters say.
He should be getting good fps with his system if it is showing 1-2fps something is set up wrongly.
There's nothing wrong with his settings, I have a very similar spec PC, and I get >40 fps all the time with high/ultra and 4xAA.
I'd try different drivers, and check some other games to see if the problem lies with Grid or not.
Thats what i advised him to do as well try aquamark and see what score he gets to see if its anything to do with the game or is it a problem with his pc.
With his pc he should be getting at least 40fps with high/ultra.
Do you use vista as i went back to xp because of loads of problems with games.
What sort of times are you guys getting on the USA track?
My best is 1:42.02 (with gamepad)
Completely useless at touring though.
> Race Driver: Grid
So ive:
Mr Latte download aquamark from here and post what score you get you should get about 110.000 with your system.
http://downloads.guru3d.com/AquaMark-3-download-673.html
Yeah, you're right. I didn't read that bit about 1-2 fps! :o Definitely something not right there somewhere.
So ive:
Whats your power supply ? Extra power cable connected to the GPU ? Latest drivers for sound card ?
Core2 quad Q6600 no overclock
2 gig Corsair ddr2 in dual channel mode
BFG 8800 GTS 512meg
Got everything set to high and it's running smooth as anything @ 1680x1050
How are you guys taking screen captures in the game?
BFG 8800 GTS 512meg
Try Fraps the best for me :)
I will look into the things mentioned and try that aquamark also thanks for the help.
SP1 is installed as are the latest Graphics drivers, i dont know how old my soundcard drivers are but i very much doubt they are the problem.
GFX power is indeed connected and using a quality 550W PSU
Will re-run the Vista performance rating thing too.
I'm about to download the demo, guys. Is it worth downloading and will it run on my system okay??
Specs:
C2D E4500 clocked to 2.8Ghz,
2GB DDR2 Memory
XFX 8800GTS 320MB
Thanks. :)
Specs:
2GB DDR2 Memory
XFX 8800GTS 320MB
Thanks. :)
I have the exact same system esxcept with 4 gigs instead of 2 (which probably makes f/a difference) and I run it 99% smoothly on medium at 1680*1050. If it didn't slow right down on one particular corner (before the big hill on USA) and if I was more of a graphics nut than a speed nut, I'd probably raise it a little.
