- 14 Nov 2006
still looks like a tart which ever way you look at it!
sorry but don`t like bile green....lol..!
So you've taken the thread off topic and insulted one of the UK's top case modders and water-cooling gurus because you don't like green? Poor show - be a man and apologise!
Anyway - on topic again - the E8400 will go to 4GHz with the right motherboard and in games, it's MHz that counts in my opinion. Very few Q6600's go over 3.6GHz on air and the extra 12% performance for a couple of pounds less makes me feel the dual-cre is the better bet in this case.
Quad core "q6600" has more cache and even if it overclocks a bit less it still pwns an e8400 look at the reviews. And when you run multiple heavy applications your pc will not slow down as you still have spare cores.
I dont think it's worth spending all out on a mega system anymore, the E8400 is a bloody good CPU and should see you through to the new generation of stuff.
http://www.guru3d.com/article/cpu-scaling-in-games-with-quad-core-processors/
But after four cores guys, I tell you, with the pending Intel Nehalem release going 6, 8 and maybe even more cores, we are bound to run into an issue. More transistors means more costly products. What really needs to go up is that processors frequency.[/U][/B]
I guess the total truth of it is Q6600, E82/8400, even something like an E2/4/6/7xxx you'd be hard pushed to be disappointed. Especially seeing as the lower down the range you go the better they seem to clock!
