£100 upgrade....do you think its possible?
10 Dec 2004
Oxfordshire
I have just sold off my PS2 and i REALLY want to get more into pc gaming and spec up my machine.
Can it be done for £100 is the question?
I have been looking at prices for stuff in the MM and do you reckon this would be a fair assumption....
E2140/60/80 around £30
P31 DS3 around £30
2GB DDR2 Ram (good stuff e.g Patriot/OCZ) £20
160/250gb HDD - £20-25
Freezer 7 - getting one from a friend for £5
Am i being a total dreamer lol :p
you really also need to consider a new graphics card if you want to do any PC gaming
http://www.overclockers.co.uk/showproduct.php?prodid=GX-071-OK
8800GT is really the only viable cheapest card you should consider if you want to game anything that is recent. But that will cost £100 for the card.
There are some ATI cards at about £80, but I can't really say how they are since I haven't had an ATI card since the 9800Pro. Although you may find some good deals second hand as people upgrade
thats the same as you asked,if you can probz stretch to a little more over budget then that setup would be ok
