WaterCooled Systems now available from OcUK
OcUK Staff
17 Oct 2002
OcUK HQ
HI there
After much research from all aspects OcUK is now offering highly overclocked water-cooling systems.
For the watercooling kits we are using the D-Tek Fuzion V2 block, EK 1/2" Hose fittings, XSPC Bay & Reservoir pump, Alphacool NexXxos Xtreme I rev2 single radiator, DangerDen ClearFlex60 1/2" tubing, Feser UV Reactive Coolant, XSPC Tubing Clips.
Here are the first two systems we have available which are water-cooled and highly overclocked:-
"Ultima H²OC HD 3870 X2" Intel Core 2 Quad Xeon X3350 2.66GHz @ 3.70GHz+ Quad Core SILENT WaterCooled DDR2 System
If you are looking for the ultimate gaming system, then you need not look any further. This system uses a Xeon X3350 Quad Core processor which is identical to the Intel Core 2 Quad Q9450 processor. However we've opted to use this processor due to the simple fact the XEON model uses a superior yield core which results in far greater overclocking headroom and cooler running. With 4 cores running at 3.70GHz+ there really is no faster processor you can find for the money, the processing power is simply awsome. Memory wise this system using a dual channel 4GB Memory Kit (2x2GB) and we've selected too use only the best Corsair Dominator kit, again as it runs very cool and delivers sensational performance. Graphics wise these machines are fitted with the best, either a NVIDIA 9800 GX2 Graphics Card or an ATI Radeon 3870 X2. Both these graphics cards feature dual GPU's giving them extensive graphics processing abilities. Basically this machine will handle any game you throw at it and even play them with smooth frame rates at huge resolutions such as 2560x1600. For multimedia the systems features the LG GCC combo Blu-Ray and HD DVD Player, which can also be used as a DVD writer too. Along with onboard 7.1 sound for true home cinema experience. The system really can do it all from playing the latest games, home cinema or been used as a professional workstation or home server. This system is watercooled hence the extreme speeds which are only achievable by using watercooling. The system is completely self contained and requires no maintenance and runs in complete silence.
- Intel Core 2 Quad XEON X3350 2.66GHz Quad Core CPU with 12MB Cache Overclocked too a minimum of 3.70GHz and beyond. (8 x 466MHz - 1866MHz FSB)
- OcUK Custom WaterCooling Kit (D-Tek Fuzion V2 CPU Block, EK 1/2" Hose fittings, XSPC Bay Reservoir & Pump, Alphacool NexXxos Xtreme I Rev2 & Accessories)
- Arctic Silver 5 Heatsink compound professionally hand installed by our technicians
- Asus Rampage Formula Intel X48 (Socket LGA775) PCI-Express DDR2 Motherboard
- Award winning Corsair Dominator 4GB PC2-8500 CAS5 (2x1GB) Dual Channel Kit (Overclocked at 1000MHz+)
- 1TB Samsung Spinpoint F1 32MB Cache SATA-2 Hard Drive
- Asus ATI Radeon HD 3870 X2 TOP Edition (Overclocked) 1024MB GDDR3 AVIVO HDTV/Dual DVI/HDMI (PCI-Express) DirectX 10 Graphics Cards
- LG GGC-H20L Blu-Ray/HD DVD±RW Dual Layer ReWriter (Black)
- Corsair TX 750W Next Generation Power Supply
Note - All Ultima systems are built and installed on demand, during busy periods this may cause a delay of between 24 and 48 hours in despatching your order. The Ultima can be supplied assembled with or without your choice of installed operating system but is supplied without keyboard, mouse, speakers or monitor (all of which are available elsewhere in this on-line store).
Price: £1239.99+VAT (£1,409.99 inc VAT)
BUY NOW!
"Ultima H²OC 9800GX2" Intel Core 2 Quad Xeon X3350 2.66GHz @ 3.70GHz+ Quad Core SILENT WaterCooled DDR2 System
- EVGA NVIDIA 9800 GX2 SSC SuperClocked Edition 1024MB GDDR3 HDTV/Dual DVI/HDMI (PCI-Express) DirectX 10 Graphics Cards
Price: £1296.99+VAT (£1,527.49 inc VAT)
BUY NOW!
Yes if you buy the parts seperately you will save a lot of money and you will not get the guarantee on the overclock either. Then our systems come with great after support service should you have any issues or a fault with the system.
any chance we can have pics of the actual PC not just an empty case?
also are WC'ed pcs appearing in the pc builders option any time soon now they can be brought prebuilt?
Hi there
Yep it will soon be an option in there along with other updates as well.
how about the W/C kit will you be selling that as an option in cooling
this would take some of the guess work out of getting a great custom W/C system
for us that dont know where to start
Seeing as these are new i think OcUK need somebody to test these machines so if you want to send me one of each of these machines i will gladly put them through there paces and i won't charge you a penny. ;)
Already been done. :p
Why it has taken months of planning to be able to offer a watercooled system.
These are ready to go from minutes before Gibbo posted, we have not left anything to chance with these babies!
How about just having a case with a pre-installed watercooling system?
You would have a pre-selected range of cases and we could select the watercooling components that we wanted you to install inside it.
Yeah I'd much prefer to build my own system and water cooling but for people who don't have experience and are beginners it’s a fantastic solution.
I would definitely update the site with a few pictures of the system and WC in action as I can imagine it's a bit of a turn off with the Antec 900 empty case in every section.
Wet the buyer’s appetite!
RoEy
