it'll be interesting to see the rest of the specs on the system.
It's probable a Celeron 900
Bit like sticking a V16 engine in a MiniIt's probable a Celeron 900![]()
Bit like sticking a V16 engine in a Mini![]()
well if you want to be pedantic i guess soI can always remember my helping my mate shoehorn a 1.4 16v engine into his old mini but he didn't have any more money to upgrade the brakes.......about a week later he never stopped at a t junction and put it through a stone wall
Brakes had failed totally.
Your anology isn't quite right though since the engine out to be the cpu. In the op's case it's a bit like taking a standard mini and putting a £5000 rally gearbox, upgraded exhaust system, carbon fibre brakes and leaving the engine alone and then wondering why it doesn't go any faster![]()
. Maybe suggest a BIOS update, cleaning out old drivers safely (Driver Sweeper etc), a little overclock on the Quad and trying a few drivers out and see if that helps.I hate to break it to both of you bu neither of you are even seeing anyhing over 60FPS, or 75FPS, unless you have some sort of fancy monitor that refreshes over 100 times a second.
With hat in mind, and to answer your question, he won't see any difference what-so-ever. Running FRAPS may give him higher numbers but he won't be seeing any extra frames.
but sure helps with them jumps
