Cheers gents, liking those Renegades Draeger, mate had a pair on his VTR years ago, sounded like the world was ending, awesome!
Mod list so far for you Dup
VFR 750 rear wheel on modded spindle
Mk2 Bros front wheel (1" wider than standard to allow 120/70 front tyre)
Penske 8983 rear shock
Racetech springs, valve emulators and modded pistons
Chromed fork lowers (blingy
Stealth products wavey front and rear discs
BSR Aerotek stainless brake lines front and rear (rear line routed inside swingarm)
Carbon fibre rear hugger
Matched stainless race headers mating into modified 2 into 1 collector
Modded Delkevic stainless race can (by modded I mean chopped in half!!)
Foam uni pod air filters
Factory 3.0 jet kit
Mods to come
6 pot Nissin caliper
Single seat race cowl (follows same lines as the original seat unit, and looks sex)
700cc kit
Megacycle cams
big valves
ported heads
adjustable ignition
slotted cam sprockets
Re spray
various bits powder coated
lots of shiny nuts and bolts
Thank god for matched betting or the missus would kill me.
Total cost so far is probably the wong side of £2k (not including the bike itself)
Fog
