The earpiece volume on my 8Gb Iphone seems to be particularly low, even when set to full volume. Is this normal and is there anyway to increase the volume?
Music too? Mines fine, in fact, it goes too loud on full volume to comfortably wear the earphones. They turn into mini speakers!
No, music when played via headphones or the loudspeaker is fine. Even when a call is received and I use loudspeaker its fine. Only when I make or receive a call and use the earpiece is the callers volume really low even on max volume.
Do you still have the screen protector on?
. I just noticed this yesterday after looking at the screen protector that came with my rubber case and noticed the openings around the earpiece and button.Yes I do...I'm an idiot. I just noticed this yesterday after looking at the screen protector that came with my rubber case and noticed the openings around the earpiece and button.
How have you been managing to press your home key? I was trying to keep the screen protector on at first, but modifying it to press the home button and hear calls. As soon as you peel it up slightly though, it gathers the entire dust from the room and looks horrid.
First day I got it, didn't want to even consider the thought of scratching it!
Seems pretty robust on reflection, although it's rarely in contact with anything without being in my homemade sock![]()
Mine sits either on, or in the Foof, never anywhere else. Whilst that's probably quite camp, did I mention gumbald's homemade sock is shocking pink?![]()
You're joking right? Gummy, he's joking yeah?![]()
I've posted it on here before!
http://forums.overclockers.co.uk/showpost.php?p=11561331&postcount=114![]()
