I wouldn't want to use a second hand air filter on my car to save a couple of pennies.
Worth paying for new surely?
open air filters such as cone filter without cold air feeds (and sometimes with) get heat soak from the engine and result in a loss of power after booting it.
As for green panel filters being compared to an OEM one, whereas the K&N one being better, WTF!!!
green and bmc panel filters are regarded as the best you can buy.
Man I'm pulling out this argument, people need to do more research
it filters less, which would be a concern to someone who knows its purpose and gives no measurable gains, plus while filtering less it spews oil on to the MAF sensor. Bargain.
B series Civics don't have MAF sensors![]()
Only if applied by a chimp?
The general consensus is not a lot of heat soak on something like a Focus 1.6 purely because the engine doesn't exactly put out a ton of heat.
I don't have a MAF![]()
but there will still be some to a degree, so if you must go down the induction kit route, an enclosed induction kit like the bmc cda will always be the best option. Unless you only care about getting a chavvy noise, where the k&n comes in to its own
