- 11 Jan 2007
- *̡̡ı ̡̡͡|̲̲̲͡͡͡ ̲▫̲͡ ̲̲̲͡͡π̲̲͡͡ ̲̲͡▫̲̲͡͡ ̲|̡̡
How would they go about this..... is there no cdkey or anything like that?
From what I have read, yes.
Just had this email:
Thank you for your recent order for Race Driver: GRID
Unfortunately due to issues with the supplier we will be unable to despatch your item in time for the release date of 30th May
We expect to despatch your order for delivery next week.
not impressed, took the day off to play it. Seems there is no stock at the stores too. Pirates have a better time and they can play it on-line. It's an outrage.
A lot of peeps are having issues getting to see options for their Controler.
Its a bad layout in the Game Menu IMO.
You need go to the driving Options/Controls Menu, it defaults to Default Profile (Keyboard), you have to move it to Custom Profile (I use the Arrow keys), then press the CONTROL Key to allow you to Config this Custom Screen by highlighting the Control you want to edit and pressing ENTER or RETURN Keys and Pressing whatever Button on your Game Pad/Controler you want to assign to it.
Can't seem to get this working properly with my G25. Apparently it's some deep rooted problem related to the registry. I've had to set up a custom config in the game for the right pedal axes to work. Force Feedback doesn't work on both custom and default settings either, so at the moment if I play the wheel is as light as a feather... which isn't good obviously.
Any other G25 owners had any luck with getting it to work properly?
Hehe indeed, been addicted to the demo like crack!
Too difficult for my driving style.There is a post in this thread with a link to instructions on how to get the G25 to work properly. Mine now works perfectly with the demo, full game has been posted so should hopefully arrive tomorrow.![]()
My wheel is definately installed correctly... was playing a bit of LFS and rFactor fine last night.I've tried that but the "Clear-Calibration" utility doesn't seem to change anythingMy wheel is definately installed correctly... was playing a bit of LFS and rFactor fine last night.
Same here, LFS, GTL, GTR and GTR2 were all perfect, but Grid wasnt... Clear-Calibration did nothing, but following the reg-edit instructions worked perfectly.
Anyone tried playing this with the 360 force feedback wheel ? really tempted to get one as I loved the demo, best racing game in years.
