) and let you know.Ive started getting this problem this morning, nothing has changed for months, even the overclock has been steady for 18 months
Im on Windows XP, DS3 motherboard, 2gb (2x1) Geil, E6300 and the BFG 7950GT
Id say it was game/graphic related as it happens when i start WoW up, but then sometime it does it while its posting. Although I havent waited long enough for blue screen, it goes blank, screen goes into standby...then i reboot.
Running now without the second monitor and its ok now, might try the game in a minute
same here not happended since i updated to 185.80 or what ever version they are now![]()
Dear sir
Thank you for having our product
We discovered very indental the mounting screws for the cooler are not tight enough , what means the cooler is not touching all memory chips, the card will be too hot and crashes . I would recommend to see if you can tighten the screws , to see if the issue is solved
It is also recommended to install the latest drivers 175.16 .
When this will not solve the issue , please return this card to your reseller for warranty
With kind regards
Point of View / Technical Department
Hmmm strange, so it seems to have worked even though your card wasn't overheating in the fist place?
What make card do you have, I don't remember seeing any screws as such. BFG 8800GTX here.
[Edit]
I take that back, there are a lot of screws
Not one of them was fully tightened. Hopefully it'll sort my prob.
