You checked the language setting inside excel or is that what you meant when you said you've already looked?
If not, start, microsoft office, ms office tools then language?
Is this a pre-created spreadsheet then? I.e. it has some data already there which you need to keep? If so, try copying the data to another spreadsheet and see what happens.Tried it - it only affects this spreadsheet thoughEven if I open a new sheet in this instance of Excel, it doesn't have the problem... :/
*n
Right click on cells, cell format, set to text or special?
