The Mass Effect (PC) Discussion Thread
It didn't put the game launch Icon on my desktop or in my start>programs>mass effect folder. In the folder its just web links with nothing in it. I had to go to c drive>program files>mass effect>binaries to get the launcher.
Is this normal?
Is this normal?
Not sure what OS you're using, but it adds an icon to my Vista games folder.
what sort of frame rates would i get on this ( spec in sig), ive got it on the xbox 360 but ive only played it twice lol i cant stand the poor framerates btw: ive heard that they have limited the amount of times you can install this game to 3 (like bioshock) is this true if so i think ill leave this game
Just got this installed.
Wacked some AA and AF on (4x and 16x respectively) runs as smooth as butter. So nice to play something like this on the PC as it's just so much more enjoyable with the smooth framerates.
Just an update guys I'd be a little wary of those audio config tweaks I posted earlier. They work perfectly for all situations except combat, where I seem to be losing some gun shots.
I might try forcing d3d and using alchemy to see if it's any better.
