Its one of those questions that gets asked over and over again, so i thought I'd do a guide, for us with nice 'normal' cars, i think if you got super cars or hyper cars this aint the thread for you
Ever since I discovered www.detailingworld.co.uk , I've been a bit OCD when it comes to car cleaning, I think, thankfully, I’ve calmed down a little and settled on a nice reasonable collection of gear, and a sensible cleaning regime.
The sort of gear you need is the following:
Washing
Turtle wash/wax & Meguiars hyper-wash, are two products I’ve used over the years, with good effect. Theres lost of other products available and most are as good as each other in my experience.
1 Lambswool wash mitt. Far better than a sponge, and you tend not to put more swirls in your paintwork with these.
2 buckets, one for soapy water, and one with clean water, the clean one is for washing your wash mitt in.
1 bottle of Tesco/aldi All Purpose Cleaner, this product is awesome, its as good as the way more expensive Meguiars stuff. This stuff you can mix up for varying strengths depending on the grime you want to tackle, I’ve used this stuff to clean my engine, the arches, door shuts etc etc its also good for cleaning flies and stuff too, it does strip wax tho.(with this you apply the stuff using a squirty bottle and scrub with a nail brush (not on paintwork tho, just rub gently with a MF cloth)
Washing is the easy part, you basically soak the car with water, personally I have a SuperSpray bottle, this hooks onto a normal hose and you fill it with your normal wash liquid, and spray it on the car, this isn’t essential, it just acts as a pre-wash.
Anyway, hose off the prewash, then simply, using light pressure, wash a panel at a time using your wash mitt, make sure you clean the wash mitt after every panel in the clean bucket, this ensure no grit is spread onto the paint work, ie no micro scratches or swirls are imparted.
If your wheels are really mucky, get some Meguiars Wheel brightener, it will shift serious crap, but you don’t want to use it on kerbed wheels as it will get into the lacquer. If the wheels aren’t too bad, use some Autoglym wheel cleaner.
Washing
