What side are you on 2day m8, ATI or Nvidia ?.
P.S, I know you swap on a daily routine![]()
Does the Radeon 4870 have the same amount of Stream Processors as the 4850? 800 isn't it?
i thought the 4870 was supposed to have more steam processors and also clocked higher?
One thing I'd like to ask about the 4870's memory clock speed - apparently its physical clock is 900MHz, but its 'effective' clock speed is 3600MHz. Doesn't that make it QDR as opposed to DDR or have I got the wrong end of the stick?
GDDR5 will deliver twice the data at an equivalent "core clock rate" as GDDR3.
Expect the marketing guys to call 900 MHz GDDR5 "3.6 GHz" or "3600 MHz" just as they call 900 MHz GDDR3 "1.8 GHz" or "1800 MHz". In terms of data throughput, it's an appropriate comparison.
I'm going to have to go ahead and say this as it's annoying me I see it a lot from you or maybe it's just me.
Helmutchesse one thing that completely ****s me off about you is you always argue the toss but then rarely provide actual links or sources to back up your argument.
You always say "Learn how to search" or as you just put it "GOOGLE" and then subsequently flame the person because they haven't. It always ends up the same
Why don't you just provide the links like the man asked instead of creating an unnecessary argument?
