Lian Li Xbox 360 Case
3 Jan 2006
South Wales
here
If this is under £30 Id buy one. I seriously doubt it will be though.
This would be ideal though as it will silence the 360 for multimedia use.
doesn't it invalidate your warenty though?
Which with the xbox's is quite an important thing isnt it?
You remove the xbox from its chassis you break the seal and you can forget warranty lian-li wasted time doing this to be honest.
In my personal experience MS will fix a 3RLOD no matter what has happened to the 360. Although I imagine you'd have to put the 360 back in its original shell.
this thread isn't about 360 returns policy but about the case.
But whats the point in the case, like Tefal says you'd have to forget about microsoft ever touching your xbox again, unless you paid for it.
But whats the point in the case.
It would hopefully be silent when in the dashboard which would allow me to use it as a media centre for high definition wma.
Like I said anything above £30 and then it is pointless.
Your looking at towards 100 notes for that case i believe its lian-li, and plus are you willing to risk your warranty?
in that case make one out of mdf.
Problem is, the sound issues that many 360s suffer from are generally caused by the disk drive. Its all very well and good chucking it into a quieter case but for some it'll still be pretty audible.
[EDIT] I want to stress i'm not knocking the 360, i just think the case is a bit of a silly idea.
