Here ya's go:
http://cid-ebcf2d90e19a4443.skydrive.live.com/browse.aspx/Asus RV770
Asus-RV770.bin and a rar with the SmartDoctor install files.
Let me know how it goes.
 check bios section at xs for updates
 It looks like there's some sort of bios lock on these cards so I guess we'll have to wait until some OC versions come out so we can steal their bioses.Hmm, I have a VF900 lying around, might try attaching it to the 4850. Got 10 vram self-stick heatsinks too so they'll do nicelyI'm very suprised the VF900 actually fits.
How did ATI manage to make a cooler THAT bad?
if you make a profile in catalyst after turning on Overdrive( make sure clock and memory settings are correct). You can then go to the file "C:\Users\Bretware\AppData\Local\ATI\ACE\Bretware. XML. the xml file will have the same name as the catalyst profile you saved. right click and hit edit.
<Feature name="FanSpeedAlgorithm_0">
<Property name="FanSpeedAlgorithm" value="Manual" />
</Feature>
<Feature name="FanSpeedRPMTarget_0">
<Property name="Want" value="0" />
</Feature>
<Feature name="FanSpeedPercentTarget_0">
<Property name="Want" value="65" />
Change the value to "manual" and Want value to "65"
Save the file then reload your profile in catalyst.
65% seemed perfect for me, 70% was loud but you may need it if your case has poor air flow.
You will have to select the profile everytime you start the computer, but it will work until there is a fix or better info so i can figure how to change the auto target temp.
Good Luck ,bretware
 Fan is ever so slightly audible, but not aggressive, have a play around until you find your max acceptable sound, and remember, anything over 20 is going to be better! This needs to get spread around really, it's ever so simple to do! Remember to open the xml file in notepad!
 I'm pretty confident that this is the best fix we will have till RivaTuner updates itself.
