Pictures of my first Water cooling build..
Man of Honour
17 Feb 2003
Chelmsford
Firsly,here is the list of components making up the the loop.
Radiator
*Manufacturer : Swiftech
*Model : MCR320-QP-K Triple 120mm
*Barb size : 1/2"
Radiator cooling
*Model : 3 x Scythe Kaze Jyuni 1200rpm
Reservoir/Pump
*Manufacturer : XSPC
*Model : Dual 750 clear Bay Reservoir with pump
*Pump Speed : 750 LPH
*Barb Size : 1/2"
CPU Waterblock
*Model : XSPC Edge Acrylic CPU Waterblock
*Inlet/Outlet Ports : 2 x G1/4
*Barb size : 1/2"
GPU Waterblock
*Manufacturer : EK
*Model : FC-8800 8800 GTX - Acetal
*Inlet/Outlet Ports : 4 x G1/4
*Barb Size : 1/2"
Tubing by Masterkleer
*ID : 7/16"
*OD : 5/8"
Fan Controller
*Manufacturer : Zalman
*Model : ZM-MFC1 Plus Black multi fan controller
I've opted not to cool the chipset.. I just felt for the first watercooling built, one step at a time.
edit - Some pictures are reduced quality as they were taken on a phone camera :
Here the Coolermaster RC1100 Sport "S" is being prepared. The reservoir/pump are in place and the rad is just about to go into the roof.NB.. The rad actually mean the top 2 bays can't be used as they take up half the space.. However, this is fine for the fan controller.
The motherboard (Asus P5KC) has been removed from the old system. I've left the CPU in the socket for the time being.
A close-up reveals 8 months of heat displacement and gives a good idea of the contact being made. Note the lack of contact on the bottom right.. I'm going to lag this later...
The XSPC Edge, Notice the fins inside..
With no hanging around, I've installed the CPU waterblock mounting screws and fitted the motherboard.
now where were we.. oh yes..
Next up, I've removed the stock cooler from my PNY 8800GTX leaving exposed GPU, RAM chips etc..
I have to say, Thjis was the part I was most worried about but ended up being the simpliest :)
With the CPU lapped and both the CPU and waterblocks in place, it's time to start fixing the tubing:
I've used cable ties just for extra re-insurance.
Once all the tubes are correctly in place, it time to start filing the res..
See the tubes gently starting to fill is a wonderful feeling of achievement :)
Next, I've attached a spare PSU using this old method..
Switching the PSU on for just a few seconds at a time allows the tubes to fill further..
You can still see some bubbles here..
The res is now full.
I've tilted the system making sure all trapped air makes its way into the res which is bled allowing the air to escape..
The pump is switched on and tested for 24+ hours.. I've left a white towel underneath. Any leaks will stain the towel, so it's a good visual check for next day..
next day.. no leaks horraa.
I've now turned the pump off leaving it to stand for a bit before final bled.
Time to start connecting everything back up and for the big switch on ..
Here it is back in the games room ..
Looks pretty cool (excuse pun)..
Full blog here on my website:
Good for you :)
Done Great there ;)
Loving the Bloo coolant (care to share info if it's available at OcUK ?)
Congrats on a very nice and tidy 1st H2o Project
Ciao
Def
Great job mate, very well done for your first w/c build. Mine was a complete mess and leaked everywhere :(
Do u have a comparison, air cooling vs water cooling temperatures? before and after? Itd be interesting to see the improvement.
Hello
did you have problems getting the reservoir to fit in the 2x drive bays? What I mean is, did the reservoir hit the cdr/dvd drive supports (runners) when you came to install it or is there a groove on the reservoir to rectify this? Was your case modified in any way?
Cheers
looks a cracker btw:):):)
Hello
Cheers
Yes, I just got some pliers and bent the said runners back into the holes until it was clear. Took a few minutes.
Hello again
just looking at the parts you bought for the water cool...I was wondering why you opted for the Swiftech radiator and not the XSPC make (everything else is XSPC). Is there any particular reason for this choice, would you say Swiftech rads are better? I am totally new to water cooling but seriously thinking about doing it. I have a coolermaster cosmos case as well but the earlier model, looks very similar to yours but has the door on the front.
That is a great place to mount the rad, I will deffo do the same with mine but will have to use the double rad and not the triple...i only have 2x 120 exhaust fans on top
cheers:)
Good job m8. Personally I would have routed the inlet to the CPU from the other rad barb therby using less tubing and do it direct instead of doing a 'loop'. Hard to tell if thats really possible but it looks like it maybe.
Yes you are right... I thought long and hard about this one. The problem here was I wanted some slack on the tubing in and out of the res as I want to be able to move this out of the drive bays to file/bled.
The bottom outlet from the rad is almost flush with the mobo so things would have got very tight and the tube would have been laying flat on the mobo and hooked round the CPU.. The reason i choose the setup is the tube from the res to the rad is laying loosly with some give.. I'm not sure if i'm explaining this to well. :)
