xbox 360 wireless
1 Dec 2006
Amsterdam, NL
is it possible? i cba lugging up another ethernet cable to plug my 360 into live, wondered if its possible to get a addon for the 360 that allows it to pick up wireless.
ags
linksys dont go well with my Be* Box :( otherwise i would have been worted lol.
mind getting a link to the 360 one, i cant seem to find it anywhere.
although, lugging that second ethernet cable up seems more effective lol
ags
Cant you just get some of those ethernet plugs that plug into your wall socket and use your existing electrical cables in the house as the extension?
Edit: Actually they dont appear to be that good and have low bandwidth (14Mbps)
I've got a set that will "apparently" go to 85Mps. I used them all of last year for playing my X360 on and found that they were pretty good actually.
I'd use them over wireless any day.
I think they site I got them from might class as a competitor though.
+1 For homeplugs. I use the ones from solwise - up to 85Mb and they are excellent. I have them plugged into plug extensions as the sockets on my wall are too low but still the performance is great. So easy to setup just plug them in and switch on.
if you've got a cable near by you could buy a cheap hub so it splits the cable then just buy two short ones for your xbox and what ever else was using the original one.
