x64 gaming questions
17 Jun 2008
South Wales
I've tried searching the internet but I find very little information about games which actually support 64 bit. Do new games such as Crysis and Call of Duty 4 run in 64 bit mode on Vista x64, or will they end up running in 32 bit compatibility mode?
All I seem to find is that Farcry, UT2004 and Neverwinter Nights 2 have AMD64 versions. Will these run on any 64 bit processor or are they designed specifically for AMDs only?
hl2 does 64 bit.
Although you do need a 64 bit os as well as processor :) (yes they work on 64 bit intels just when they came out only amd had 64's)
oh and CLAIMED :D
32 bit comp. mode
Except for Crysis afaik.
I'm not sure, would like to know this too, although I'd expect them to run fine on intels x64 extentions too.
No not yet, HL2 and lost coast does, not sure about any of the others.
Only games that use the Ep2 incarnation of the Source engine, iirc..
*edit*
although they debuted 64bit back in December 2005, so I'd *expect* Ep0/Ep1 to have it too..
*edit*
Ep0 has it that's for sure, a pop-up on the top says 64 bit on starting the game.
damn, errm, trying to remember all the games that did. Hellgate does, bah, frankly theres not a "huge" amount of difference and lots of games simply install without the option but detect the OS and install the appropriate .exe file. Simple thing is lots of newer games and more all the time will have 64bit versions and will just install automatically. Some games are faster in 64bit, not much but to be honest I think right now recompiling an exe to run in 64bit is about as far as most of these guys are going, optimising and spending lots of time making 64bit run faster hasn't seemed to be a massive priority yet. Really should have only bought around the 64bit vista, as with only one version to support pre-release everyone would have had working 64bit drivers, but to many companies gave 32bit support and threw out a crappy 64bit driver which affected the uptake of 64bit version massively. WHich in turn means dev's have little reason to put "that" much effort into 64bit, was a bad call all around as MS could have had significantly less work with only one version of the range to support/produce/optimise.
I think Farcry may have only been supported under the AMD ath 64 chips but at the time I think they were the only 64bit chips out so not surprising, would assume it runs fine on Intels too.
If its a case of not sure which version of windows to buy, go with 64bit, if its just wondering, well I guess check all your folders, most will have some indication of .exe version being 32 or 64bit, or in the install log or version txt, readme or something like that.
The thing thats really stupid is often its a pain to install a different version on your computer. For instance I wanted to mess around with a trainer on Hellgate in single player to rush through some classes and see which I liked at later levels, installed on vista 64, trainer makers all made 32bit versions and there wasn't any way to install the 32bit files on 64bit, installing on a different computer and transfering all the different files and it worked fine in 32bit. But seeing as some games have bugs in either version, or some reason you want to run, its weird they are making it so seemless and hidden. If a game can be installed and run at 64bit you'd think that would be a selling point like any other gimmick and option in install menu's to highlight how "advanced" their game is makes sense.
i believe most games will have a 32bit and 64bit .exe like Assassins creed?!? or it will auto detect i guess.
/shrugs
