If they get the Phenoms clockable then I would be interested in an all-AMD rig.![]()
I just like matching stuff is all. If AMD brought out a quad-core Phenom that clocks nicely I'd possibly be interested in buying one, especially since my Q6600 clocks utterly rubbish.Why?
Will they suddenly match your Q6600 or something??
On that page I read something about interoperability between 3800 & 4800 cards...am I reading that right???? Would be awesome if so!
*Imagines my 3870X2 paired with the 4870 coming tomorrow and drools.*http://www.tgdaily.com/content/view/38056/135/
"A source close to AMD told us that there will be “inter-generation compatibility” between the Radeon 3800 and 4850: “Since they're both DirectX 10.1 parts, there is no reason why those two should not work together. (…) We will probably not qualify this interoperability, but who stops you from trying?"
It appears that ATI did not integrate a driver lock or something else that would stop you from combining a 3870 card with a 4850 or with a 4870 model. Just keep in mind that these two cards need to include the same amount of memory. If you mix and match a 3850 with 256 MB of memory with a 4850 512 MB, the 4850 card will default to 256 MB. If you wonder whether you will be able to combine a 3870 X2 card with a 4850 board, our sources indicated that this scenario should work as well."
This would be awesome if so....especially for the 3870x2 owners!
I only have 16x/4x (P35 board) but I will give it a go for you.Can you try it Ulfhedjinn and let us know if this works? That would be a very valuable piece of info for a lot of people I think (me included!)![]()
Performance is not important, seeing if it actually works is!
Nah I am pretty sure they're 16x/4x, I know my Abit IP-35 Pro is.I was under the impression P35 went to 8x/8x in Crossfire.
