- 10 Apr 2004
What density does the high tech industry settle on? :S
I think high tech industry will settle when your sims are educated enough and you place them away from air pollution but close to residential areas.
low/mid density. Place parks around the zone and bulldoze any dirty industry that grows.
. High density is fine too.
) and leaving high tech at 9% or even lower.High tech very anti pollution, like all high wealth. To get it and not dirty industry, put the dirty industry tax at 20% and zone low/mid density. Place parks around the zone and bulldoze any dirty industry that grows.
Can you get yours to run at that widescreen res? I can't, no matter what shortcut switches I use.
so is there no where to download peoples regions/cities?![]()
Ah lame :/
Bug posty in every thread he posts in. You'll get his region eventually![]()
whos region? where where where!![]()
I just can't get the hang of it - I build loads of industry in a single tile, inc. power and water and stuff and send it over to the adjoining tiles, and sure enough I get some cash, but I just seem to run my funds into the ground - do I still build residential in these "industry" tiles?
Or even better - are there any guides of any sort about this?
I use this tag on my shortcut. Works absolutely fine.
Hope it helps.
"C:\Program Files\Maxis\SimCity 4 Deluxe\Apps\SimCity 4.exe" -CustomResolution:enabled -r1280x800
High tech will grow on high density zones but so well the biggest dirtiest factories, the later won't grow on med density but the high tech will. Which is why you don't tile high density industry.
To my knowledge densitys are best used as low as possible to get small-medium growth, and then once you've got a nice region going and you've run out of land.. rezoning parts of your low/mid-density to high will give you nice big buildings. By zoning too big to begin with, cities can get wayyy out of control.
