You could try 1 WU just for the hell of it.Cool graph. Probably not worth trying to fold on my 8400GS.
I wonder what impact the CPU has on the ppd? Did I read you need 1 core to feed the GPU?
Certainly put my 900ppd on SMP to sham
Well I just tried it on the 8400GS and I can't get it to work. Downloads work and then errors saying that it couldn't find cudart.dll. I'm using the 177.35 CUDA drivers.
[12:49:57] Project: 5004 (Run 9, Clone 41, Gen 24)
[12:49:57]
[12:49:57] Assembly optimizations on if available.
[12:49:57] Entering M.D.
[12:50:03] Working on p5002_supervillin_e1
[12:50:04] Client config found, loading data.
[12:50:04] Starting GUI Server
[13:03:47] Completed 1%
[13:17:31] Completed 2%
[13:31:02] Completed 3%
[14:11:47] Completed 3%
[14:11:48] Starting GUI Server
[14:25:34] Completed 4%
[14:39:07] Completed 5%
[14:52:35] Completed 6%
[15:06:01] Completed 7%
[15:19:30] Completed 8%
[15:33:00] Completed 9%
[15:46:31] Completed 10%
[16:00:01] Completed 11%
[16:13:30] Completed 12%
[16:26:59] Completed 13%
[16:40:36] Completed 14%
[16:54:09] Completed 15%
[17:07:46] Completed 16%
my 640MB 8800 GTS is giving me 3,600 PPD according to FAH.
(CPU is an Athlon 64 X2 4600+) btw
FAH is reporting some crazy readings for my 8800 GTX, but the PPD value for that is quite a bit higher in the high 4,000 range. (CPU is QX9650, percentage load is 5% on one core)
