Vista runs really well on my CD 2.0Ghz 2GB RAM MacBook under bootcamp, all the drivers install fine and everything works including Aero. It runs as good as a 'PC' laptop would have identical spec except it looks nicer.
If you stick in your Windows XP/Vista CD, reboot, hold down C (boots from the disc), delete every partition and install Windows... You will now have a very expensive Windows laptop!
That is what Boot Camp does...except it allows you to dual boot Windows and Mac OS X
So basically bootcamp means u can choose either OS X or Windows to run, and with parallel u can have windows running from os x using a 3rd application?
