Are you being sarcastic or are you saying you know more about buildings than architects?
This is shocking. The bbc yet again in a biased documentary..
It doesn't seem biased to me. They seem to be covering the points AGAINST it being a controlled demolition quite a lot.
Wasn;t this the building the bloke said ''pull it''. Was it the mayor or some official. A term usually meant to mean bring it down in demolishing terms as I assume you lot know. So this building may have been pre-packed with explosive ??? dunno ..
yeah, as I said this part is very good. However the beginning of it about the free fall and comparing it to other towers was not. It was 100% biased with no counter claims and they weren't even asking the right people.
Fixed.![]()
And if you're so knowledgable about the design of the Towers, then you'd also know that the metal structure is built to withstand the heat that could be caused by jet engine fuel. It was also designed with aircraft impacts in mind. Look it up, the actual structural designer for the Two Towers has spoken out about it.
*Sigh*![]()
