Limited looks the same on both my TV's, exactly the same. Full RGB only works right on my new panel as it fully supports it. I'm not talking movies or games, it's as simple as looking at the XMB, changing the settings and you can see the results instantly. The fact is, limited setting does tend to look washed out, it's been a complaint of many users. Full RGB, if supported, looks lush. If the OP does not have a set that supports full RGB then he'll come to the conclusion that he has, the PS3's colours look washed out... which is the point I'm making
