there's no saying a simple volt mod will be possible like with the 4850, looks almost like a digital VRM.
Not pencil mod or bios mod?
You rekon I'd have a good chance of getting to 850-900 with say an S1 and upping the voltage when its possible to do so?
With a voltage mod I'm sure 900 will be easy if not more. I think the stock cooler is pretty good if you manual adjust the fan and can stand the additional noise. I couldn't comment on the S1.
Why don't you try water?
I decent loop is one of the best investments you can make if you want to overclock and have a quiet reliable system.
Water is too much, I dont have the money, when I go to uni and if I find a decent student sort of job I plan on saving up and around christmas time moving to quad core and possible a crossfire setup as it would be something new and a first for me.
Bad luck mate, that is indeed the worst 4870 o/c I have seen by quite a chalk.
mine will only do 780/1050 after that it artifacts in ati tools with fan speed at 40%,idle temps are 42 and load is 60,gutted when i see what everyone else is getting
With the GPU benchmark I'm getting 43 FPS Avg at 1920x1200 everything high apart from post and shadows at medium in DX10. Thats stock clocks on the 4870 with my Q9450 at 3Ghz.
The 4870 destroys my 9800GTX @ 850/2500.
You need 4 or 2 depending. The VRM's ( 4x ) are tiny so you will need to hacksaw a low profile heatsink and use some double sided stickytape with possibly a dab of hot glue to secure the mount.
Same settings just at 1680x1050 I get 46.195. Are you running on a slipstreamed vista and before you ran the test did you exit everything or something?
I must be cursed, I try make my overclock as stable as possible on cpu and ram and all that THEN I optimize vista slipstreaming it making it run quick and I still get crap fps I must be cursed
On top of that Grid crashes when I am running at 790/1000 now![]()
Thanks for the info matenice one !!! Should have enough sinks by the looks of things
Rob
Just the Business Vista Install with lots of things running. A none tweaked setup apart from Indexing is turned off.
