I was just wondering which he'll switch to when he has problems with XP.hey, I was running windows 2000 pro for AGES, only switched to XP after SP2 had calmed down!
Because, in my opinion, he will have problems with XP if he has them with Vista.
Well the one bug that I would consider a "deal breaker" is the file copy issue. The fact that XP's approach is bugged is moot, given that it doesn't crash the explorer like the Vista one does.
It also makes working with large compressed files a nightmare - I would also get an explorer crash trying to open an archive larger than about 200MB.
I don't understand why something like that isn't caught during testing. I'm not defending XP at all in this case - i'm just wondering why such a problem made it through.
It also doesn't help that I can't seem to get SP1 to install on my Vista - no matter what I try it always corrupts the install. And i'm not willing to go without it.
Where would I get one from?
And also, Vista is so slow updating. It's awful. I thought it was my internet, but it comes up at 7.5MBit on a bandwidth test. Any suggestions?
File copying on Vista SP1 is much faster than XP for large files. Takes a fraction of the time. Took me few mins to copy 45GB and XP was saying it would take 6 hours!! If SP1 will not install for you it is usually because you have a device which does not have recent drivers. Creative soundcards are the biggest culprits here MS have articles and advice on how to get around this.Well the one bug that I would consider a "deal breaker" is the file copy issue. The fact that XP's approach is bugged is moot, given that it doesn't crash the explorer like the Vista one does.
So I need an update to fix the problem where updates are slow to download?
You couldn't make this up....lol!![]()
they always point out that its imposable to check that every combo of hardware and software works, because it is. no two setups are identical
And even when two setups are exaclty the same they can behave differently.
Burnsy
Really whats all the talk about snow leopard being 64 bit then ?![]()
exactly
we've 5-6 desktops we ordered at the same time, same spec, same software, same updates etc, used for the same thing and no two have ever had the same issues! (all vista, all working fine atm)
