Dry traction
Dry traction is measure of the tire’s ability to deliver traction, or grip, under dry conditions. Dry traction increases in proportion to the tread contact area. Dry traction is also a function of the tackiness of the rubber compound.
[edit] Wet traction
Wet traction is measure of the tire’s ability to deliver traction, or grip, under wet conditions. Wet traction is improved by the tread design’s ability to channel water out of the tire footprint and reduce hydroplaning. However, tyres with a circular cross-section, such as those found on racing bicycles and motorcycles, when properly inflated have a sufficiently small footprint to not be susceptible to hydroplaning. For such tires, it is observed that fully slick tyres will give superier traction on both wet and dry pavement.[11]
[edit] Force variation
The tire tread and sidewall elements undergo deformation and recovery as they enter and exit the footprint. Since the rubber is elastomeric, it is compressed during this cycle. As the rubber deforms and recovers it imparts cyclical forces into the vehicle. These variations are collectively referred to as Tire Uniformity. Tire Uniformity is characterized by Radial Force Variation (RFV), Lateral Force Variation (LFV), and Tangential Force Variation. Radial and Lateral Force Variation is measured on a Force Variation Machine at the end of the manufacturing process. Tires outside the specified limits for RFV and LFV are rejected. In addition, Tire Uniformity Machines are used to measure geometric parameters including Radial Runout, Lateral Runout, and Sidewall Bulge in the tire factory at the end of the manufacturing process as a quality check.
