2 gfx cards and 2 monitors on the same system, just a case of plugging in ?
4 Feb 2003
telford, shropshire
waiting for a crossfire bridge to run my 2 1950 pro's in crossfire, just wondered if its as simple as plugging the cards in then one monitor to each card ?
cheers.
with standard crossfire enabled Im not sure you can use dual monitors
I have been advised with the new cards this is possible but I havent seen it myself - it might be wholly driver related in which case you will be ok - let us know how you get on:)
got the 2 cards/monitors working, but if i start a game on my main monitor i have to alt/tab out of the game to access the other card/monitor is there a way around it ?
thx.
thx.
You would have to do that anyway, no matter what (well I tell a lie there is the option of playing the game in a window, but I believe that usually crucifies performance, if its even possible - I dont think all games like it/allow it)
