You can tick the box marked "ignore asynchronous clock" in the monitoring section of options in FahMon to get rid of the *hung* message
8800GS uses a whole core of my Q6600.
Are you on XP?
So far I have noticed:
My 8800GTS is on Vista and is uses 3% of a Q9450
My 9800GTX is on XP and is using 50% of an E6600.
Verbals is on Vista and is using 39% (high because it's an old single core processor)
If you are on XP and your 8800 GS is using a whole core that could be the problem and there could finally be a good reason to switch to Vista
Yeggestry Vista or XP?
though IIRC Yeggstry is on XP, so his results don't seem to fit the pattern![]()
toTOW said:We still don't know exactly why XP always shows 100% ... maybe an overload related to the way driver/kernel communication works in XP. Keep in mind that Vista introduced a new driver model.
You can point me to where that is please?![]()
Dunno why but my GPU client is using much less CPU time today. It's PPD has fallen by about 150, by the 4 linuxSMP clients have gained about 150ppd each.
