40nm RV870 "Lil Dragon"
2 Sep 2006
Forest Grove, OR, 'Merica
good stuff ehh? :D
Source: http://www.nordichardware.com/news,7999.html
It's been known for some time that RV870 would be a shrink of RV770. The node following 65/55nm would be 45/40nm, but we weren't sure if AMD would go to 45nm or directly to half-node 40nm. It's now clear that AMD will go directly to 40nm and aim for a performance per watt ratio twice that of RV770. RV870 has been code-named "Lil Dragon", which does indicate that this will be something small, yet something to fear.
The overall performance has been suggested to be somewhere around 20% better than RV770 with a significant drop in power consumption. This points to 960 shaders (192x5), 48 texture units, 40 ROPs and so forth. If this is the case, TDP of the RV870 should be around 150W at most with today's frequencies. This is just an estimate on our part as technical specifications are still hard to come by. We also presume AMD to stay at DirectX 10.1 for now.
THe fab plant where they have their cards made has said they will certainly not have 45nm ready till end of Q1 next year, EARLIEST. They had planned it for late this year but two separate press releases one a few months ago, one last month had delays listed as reasons it got pushed back.
Won't see die shrink till then unless for some reason TSMC manage to get online earlier which isn't likely.
I can imagine a Q1 Release for this. Along with an R870x2 =D with the power requirements of a single 4870 =O
think i know my next card. What's left after 40nm, will it be down to 32 and so on. if so what will the manufactures use when they can no longer shrink the silocone?
i read about very small diameter carbon nanotubes that could prevent electron migration in the future on very small nm processes.
