2900XT Video In
6 Sep 2006
London
Hey guys, really baffled by this one.
I know there's a lot of confusion between VIVO (Video In, Video Out) and AVIVO (hardware codec), it had me confused at first too. Basically just because a card has AVIVO it doesnt mean it can do video capture from component or S-Video.
However my 2900XT came with a cable that clearly shows S-Video in and component in as well as the two out. I haven't been able to get either in or out to work. I have the additional 8.7 AVIVO drivers installed and yet it still doesnt show up as an input stream option in VLC and trying to output via component to my TV doesn't work, though that could be the TVs fault (cheap TV).
What's I'm trying to do is hook my NTL TV box up to both the TV (which works) and the computer via a Scart to component splitter. The audio works fine and comes in through my line-in no problem. The video-in though refuses to show up at all.
Has anyone got video-in to work on an ATI card and how did you do it?
i had it working...
u need to have the ATI T200 AVStream Capture driver installed then just use your favourite app and choose ATI T200 AVStream Capture as the source.
Thanks gareth, just found the WDM drivers, I had a different set of additional drivers that mustn't have been the right ones. Will see if this works now :)
check in device manager that you dont have any drivers with yellow exclamations
The ATI T200 device cannot be started. I've had this ever since I first got the card no matter what drivers I've used with it. Any idea how to get it installed correctly?
ive had that too..
get the ati 8.3 drivers... then go in "C:\ATI\SUPPORT\8-3_xxxxxx_dd_ccc_wdm_enu_59753\Driver\Packages\Drivers\WDM\AVS_T200" this driver worked for me
xxxxxx = your os
Thanks for the help, I tried 8.3 WDM drivers both the automatic install and then manually directing to the folder with them in. Both gave the same device cannot start error.
