Hi
As seems to be the vogue at the moment, id really like to try watercooling.
I have a Coolermaster 832, Striker Extreme, E6850 @ 3.6Ghz, Sythe ninja Cooler, 4GB Crucial Ballistic, 2 x Msi 8800GT's (S1 GPU coolers), 750W Toughpower.
This lot runs at around 50c idle and 60-65 load. Room temp is around 20-25 id guess.
Ive been reading endless reviews on kits and custom setups, and read a lot of threads in here, and id like to go down the road of custom.
Ive picked out some parts and would appreciate your advice:
Pump/Res: http://www.overclockers.co.uk/showproduct.php?prodid=WC-010-XS
CPU Block: http://www.overclockers.co.uk/showproduct.php?prodid=WC-000-DT
Rad: http://www.overclockers.co.uk/showproduct.php?prodid=WC-041-AC
Coolent: http://www.overclockers.co.uk/showproduct.php?prodid=WC-049-PM
Tubing: http://www.overclockers.co.uk/showproduct.php?prodid=WC-001-PM
Now im a little confused about all the different tube sizes 1/4 -1/2 - 3/4 etc Are all the connections on blocks, resoviors standard, does all tubing fit all blocks, resoviors etc? (sorry if thats a stupid question)
That lot is about £120 + delivery which sounds ok, can i expect better cooling than current setup?
Anyho fire away.....
