i now own Eibach Pro Street coilovers
http://www.eibach.de/index_2.php?SP...=135&LID3=112&LID4=27&LN=Products&ACT_LID=135
* Eibach Pro Street Coil-Over Shocks are custom-paired for your vehicle
* Adjustable lowering from .8" to 3" for tuning performance to track conditions
* Uses Eibach's ERD damper and ERS spring technology used in Formula-1 racers across Europe
* Harnesses the experience and fine-tuning of Eibach's legendary suspension parts
* Eibach Pro Streets get progressively firmer at high speeds for excellent ride quality
* Bolt-on installation takes 1-2 hours for all four wheels
* Set of 4 shocks
* Your Eibach Pro Street Coil-Over Shocks package carries a 1,000,000-mile warranty
Description
Finally, suspension parts for street rides that performance enthusiasts can truly be proud of. Employing the same Eibach technology fueling fine-tuned Formula 1 racers, Pro Street Coil-Over Shocks give serious drivers the control they've always wanted.
Eibach Pro Street features the incredible option adjustable lowering for each wheel. You have control of dropping anywhere between .8" and 3" for fine-tuning your ride to any track conditions. Pro Street coil-over spring/damper packages also feature Eibach's legendary suspension know-how, getting progressively firmer at high speeds for excellent ride quality.
Wheel out your toolbox, clear the driveway and grab some jack stands. Mounting new suspension parts takes time and care to complete correctly and safely. Rest assured, Eibach's quality tuning and expert quality make it worth your time. And, your Eibach Pro Street Coil-Over Shocks package carries a 1,000,000-mile warranty.
