new shoes on the golf (it was a gamble)
13 Mar 2004
i guess this will be a Marmite thing
pepperpots :D
audi branding... theyre off an A3 lol
its definately part of the vag/gti thing to end up pinching stuff off other models.
a lot of time was put into polishing up the rings, they are mirror like. someone took some pics, cant find them at the moment though
the new tyres are Khumo KU31. impressed with those so far too. ill do a write up on their performance soon. they are impressive too
You look tiny in that pic O-o
Also... It ain't rubbin
its a mk3. they are friggin enormous *cue mk3s being heavier than the moon gags :p
as for the rubbing... that could be being cured very soon, but seeing as the car has been put together for b road thrashing, i need to keep the ride height practical.
when i get new suspension again, ill keep you posted
Those wheels look really good on the golf. But i think they'll look so much better if you remove the Audi badges from them (if you can?)
the audi badges are not that noticeable, i think it also adds to the "they came from totally the wrong car" aspect of it
also they are no removable. they are molded as part of the centre cap, they attach from behind
they do look pretty 'ard without caps actually
I like them, as said though. Remove the Audi caps, sand them away and get some one to get VW done on em? Would look nice.
Looks good, not enough tucking in the front though :p Understandable that you don't want it totally slammed if you actually drive it properly though.
i now own Eibach Pro Street coilovers
http://www.eibach.de/index_2.php?SP...=135&LID3=112&LID4=27&LN=Products&ACT_LID=135
* Eibach Pro Street Coil-Over Shocks are custom-paired for your vehicle
* Adjustable lowering from .8" to 3" for tuning performance to track conditions
* Uses Eibach's ERD damper and ERS spring technology used in Formula-1 racers across Europe
* Harnesses the experience and fine-tuning of Eibach's legendary suspension parts
* Eibach Pro Streets get progressively firmer at high speeds for excellent ride quality
* Bolt-on installation takes 1-2 hours for all four wheels
* Set of 4 shocks
* Your Eibach Pro Street Coil-Over Shocks package carries a 1,000,000-mile warranty
Description
Finally, suspension parts for street rides that performance enthusiasts can truly be proud of. Employing the same Eibach technology fueling fine-tuned Formula 1 racers, Pro Street Coil-Over Shocks give serious drivers the control they've always wanted.
Eibach Pro Street features the incredible option adjustable lowering for each wheel. You have control of dropping anywhere between .8" and 3" for fine-tuning your ride to any track conditions. Pro Street coil-over spring/damper packages also feature Eibach's legendary suspension know-how, getting progressively firmer at high speeds for excellent ride quality.
Wheel out your toolbox, clear the driveway and grab some jack stands. Mounting new suspension parts takes time and care to complete correctly and safely. Rest assured, Eibach's quality tuning and expert quality make it worth your time. And, your Eibach Pro Street Coil-Over Shocks package carries a 1,000,000-mile warranty.
