Deleted member 651465
I've been examining my phone under a 400x microscope at work today. My vibrate/ringer switch on the top left has a fracture at the join... :/
You would be happy with this..
Nope - not yet!I'm considering on buying a 3G iPhone on the bay. Can these be jailbreaked/unlocked to allow my payasugo o2 sim?
Thanks.
Nope - not yet!
*snip*
Wusthat a picture of?
Yay, got my iPhone.
Can you stick a payasugo o2 sim and let me know if it works?
I'm confused, can I use my normal payasugo sim with the iphone 3g, Ol!ver?
Can anyone with a 3g iphone stick a payasugo o2 sim and see if it works pretty plz?
Now i'm guessing.. perhaps.. that my battery guage isn't working. Either that or i have one hell of a battery![]()
Second iPhone 3G.. second problem
2) Light leaking from left side of the screen (roughly adjacent to volume rocker switch).
Getting my THIRD tomorrow.
I urge those with the light leaking issue to report it so it can be recognised as a fault.
- Pick up phone to head height
- Activate screen / turn on phone
- Tilt phone at 40-45 degrees
- Look at the edge of the screen (left side)
If you can see the light, get a replacement (or a refund)
