Teaser: R32 Project.
Have you contacted G-Werks at all mate? I know they are building a VR6 Turbo with a similar power aim, they could do the mapping maybe.
wtf. what sort of performance would that much powah give?
Going off the HPA R32 with 550bhp
0-60 3.2s
1/4 mile 11.5s
top speed - 202mph
all verefied by Dekra in Germany so not tuners bull!
I'd say that with an extra 100-150 brake the 0-60 will possibly increase due to 4-wheel spin in 1st & 2nd (the HPA car spins all 4 up to 30mph)
1/4 could drop below 11secs and the top speed will not increase without new gearing (the HPA car is 200rpm under the limiter at top speed)
but it will be very, very quick!
This just makes me want an R32 even more :(
I would have the MK 4 over the MK5 though, definitely in the same blue!
Looks like a good project going there too :)
Did you look into any better manufacturers before settling on Wossner pistons, like Cadbury's or Nestle?
Should be very interesting if you do get it to 650 bhp :eek: What is your transmission rated at?
Sounds like an awesome project. However, I don't mean to **** in your teacup but won't the gearbox/drivetrain melt under that sort of power?
I have a friend who ran slightly more than that on an evo and he went through gearboxes and rear diffs like I go through pringles. However this was mainly due to drag launches :D
The drive train is remarkable strong and quite a few R32s with FI take around 700bhp before any serious upgrades are needed. I think this is due to the system basically being the same as the one in the older 2.7 Twin Turbo RS4 so fairly underrated in a standard R32.
The clutch/fly wheel however need a serious upgrade.
cant see it happening really, not 600+ bhp without serious serious work.
Serious work indeed :)
Well, i have heard the same things off a few other people that the wossner pistons are a bit 'soft' compared to the others, however there are a few people that have been running these pistons fine. I still not sure what compression to run at yet, so i could quite easily swap these out for another set.
The stock pistons and rods are good for 600bhp, the stock crank for well over 1000bhp, the gearbox is good for about 450/500bhp. The clutch, as has been said, has been significantly upgraded, using clutchmasters stage 4 carbon ceramic 6 puck single disc (might upgrade to twin plates yet)
Believe me when i say there are many, MANY doubters out there. However, with the research i have done, the contacts and friends i have made, this will be and IS going to be possible. I am not going to rush it, the front end is off the car currently, and im just waiting for some space to clear up at a friends garage so i can use his ramp to finish removing the engine.
Someone mentioned and R36 base, this was considered, however they are still quite expensive (5500eur on german ebay) and that would cut into a big chunk of what else i wanna do.
Back to the gearbox, the weak link is 3rd gear, however the selectors have already been changed with updated versions, and i will be using the HPA/HGP gear set which upgrades the gearbox further.
I've also heard people not rating the Wossner pistons very much, but then I've seen them used successfully in many applications so who knows :)
0-60 3.2s
1/4 mile 11.5s
top speed - 202mph
If that can be used as a daily comfortably, I'm impressed. I'm assuming that's 550atf, so what in God's name will a possible 650whp be like?
Nice one, this could be special.
omega pistons in birmingham, have said they can make me some at a reasonable price if needbe, they are who my dad used to use for the rally cars he built.
I've heard a lot of people bad mouth Wossner pistons as being "soft"
But (in my mind this seems logical, I know literally nothing about high power engines) I'd rather damage a piston than damage the block.
