but it'll be only about 5-8fps differents between xp and vista.
what drivers u using?
8.7 stable
Doing crysis bench now
all games at stock clocks having artifacts =/
If anyone successfully or unsuccessfully uses a 4870x2 with a 600W PSU or thereabouts please let me know =)
I'm going to be fitting my HIS 4870X2 tonight with a new Corsair 620 PSU so I'll post back some time later tonight.
Just say what you want pics of and I'll hook you up =)
Yeah the Corsair 620 is working fine
Yeah the Corsair 620 is working fine, just got it all up and running and have been playing Crysis on all Very high settings for the last hour. no glitches and nice and smooth. Ended up using the drivers with the card as couldnt get any ati ones to install from amd's site, as I just mentioned in another thread.
How many power connections does the card have? My old 8800GTX had two so I'm hoping this isn't the same, just found the adaptors for £20 each....
[edit]
http://www.3dgameman.com/vr/his/hd4870x2/hd4870x2_12.jpg
Just found this pic of the HIS card, looks like one 6pin and one 8pin
Sorry to repost but does the Corsair 620 have the correct 6 and 8 pin power connectors?
