4870X2 PSU/Case requirements
29 May 2005
West London
I have a Antec 900 case and a HX620W. I am tempted to go after work tommorrow to pick one of these bad boys up.
Will it A) fit B) blow up my PSU?
a) most likely
b) no it wont kill your psu, hope it doesnt anyway as its the same one i have and plan to run an x2 through it at some point
Same case and psu as me, im sure its same length as 8800GTX which fits ok in mine although it leaves a couple of the sata header connectors difficult to access, in terms of aiding the cooling for the likes of the X2 then its a great case, I have top fan 100% and the two at the rear on 100% + got additional one on side window blowing cool air over the GTX, ambient case temps are very low compared to various mates cases with same hardware, see no reason why it wont be good for the X2
Someone in another thread has an X2 working on this psu with a quad6600 running at 3.2 so its looking ok, also if your lucky like me the psu will already have the 2x6 pins each with an attatched 2 pins for which one of them will be needed for the X2
It will fit with the hard drive fan mount removed. Yes the HX620 can power it fine.
Yeah the Corsair 620 is working fine, just got it all up and running and have been playing Crysis on all Very high settings for the last hour. no glitches and nice and smooth. Ended up using the drivers with the card as couldnt get any ati ones to install from amd's site, as I just mentioned in another thread.
cool, just gotta source the 6+2, my 620 lacks them, sent an email off to corsair see if they can do so, since they have a policy on cable replacement anyway
