Can I just say if you can screen grab (alt prtscrn) the fault and every one else can see it then the fault lies with the graphics card, drivers or even settings.
All alt prtscrn does is take a copy of the buffer on the graphics card.
Make sure you have the correct bit depth set, 24 bit or above latest GC drivers.
Ive just tried photo shop gradient and see no such phenonemom
Far too many problems with this monitor for the price. I sense it's worth waiting atleast a year until the choice of monitors available really begins to improve.
nightrhyme,
I, and im sure others here are too, hoping the HZ26Wi 26" turns out to be just as good quality as HZ24Wi 24", and as a bonus, its input lag being much better for gaming.
Do you have the hazro calibration suite? These monitors has a LUT calibration hardware like the nec 2690wuxi?
Oh i made the screenshot for anyone who didn't want to download the program. I'm fairly certain the bands aren't on the source image as it never showed on the digimate 24" or my CRT.
Thanks for testing it on your hz24wi, you don't get the same effect that i do on a non-dithered vertical gradient? That narrows it down a bit. If you could try checkemon that'd be great too.
Thanks jack.mitchell too, i haven't really got access to a decent camera to photograph it either, but like you say, the distortion in the bands below the cursor is just like someone ran the smudge tool down the image.
You just have to tell the software to maintain original aspect ratio (default action for virtually all software)Anyone using a HZ24Wi on a Mac (Pro)?
Received mine yesterday, and have noticed a few foibles. When the Mac goes to sleep the display pops up a box saying that it can't display the image and never switches off. However if you turn it off then on again (while the mac is still sleeping), it says "no signal" (IIRC) for a bit then goes to sleep like it should.
Is this the same DPMS issue that was reported with the previous model?
I'll plug it into my G4 Mac Mini, as this also suffered from the DPMS issue with the old revision. Will report back shortly!
Cheers
Jim
You can also get closer to the 120cdm2 recommendations for an LCD for calibration by dropping all the RGB colour values to a lower value, default is +90 for every colour so drop it to say 50 then calibrate from there because at 90+ for each the cdm2 is over 400 at 50% brightness on the OSD, 0% brightness is still a high 300cdm2 !
Goes to sleep fine on mine, I set it to put monitor to sleep after 1 min, it then flashes up the "no signal", first in the centre and then moves that about the four quadrants of the screen, it then flashes up "Going to Sleep" in a similar manner and turns off.
This is a G4 era Mac Mini with a discrete Radeon graphics chip.
What if you put the Mac itself to sleep though, rather than just the display?
Thanks,
Jim
