21 Aug 2008 at 22:55 #1 Jimmy1983 Jimmy1983 Soldato Joined 1 Mar 2007 Posts 4,795 Location Portsmouth When you do a backup are all your contacts saved?
21 Aug 2008 at 22:57 #2 tem07 tem07 Associate Joined 19 Mar 2007 Posts 617 Yep. That's what happens when I do a firmware upgrade as well.
21 Aug 2008 at 23:01 #3 Jimmy1983 Jimmy1983 Soldato OP Joined 1 Mar 2007 Posts 4,795 Location Portsmouth tem07 said: Yep. That's what happens when I do a firmware upgrade as well. Click to expand... Just upgraded to 2.0.2, but will do another backup incase. Do you lose anything, are the messages kept?
21 Aug 2008 at 23:19 #4 tem07 tem07 Associate Joined 19 Mar 2007 Posts 617 I just did an upgrade as well, nope - everything is kept. All settings everything.
21 Aug 2008 at 23:31 #5 Jimmy1983 Jimmy1983 Soldato OP Joined 1 Mar 2007 Posts 4,795 Location Portsmouth tem07 said: I just did an upgrade as well, nope - everything is kept. All settings everything. Click to expand... Yer worked ok, thanks although itunes has just hung but think it finished the restore. All settings are back. Didnt sort my problem out tho
22 Aug 2008 at 01:09 #6 Jimmy1983 Jimmy1983 Soldato OP Joined 1 Mar 2007 Posts 4,795 Location Portsmouth If I get a new handset, would I be able to do a restore on it to get all my details back from my previous phone?
