E8600 E0 Overclock Database
Core 2 Duo E8600 Only!!!
There will not be a lot of E8600 owners, So need as many entires as possible to build a decent database.
Please use this thread for discusion to keep it active
THE DATABASE:
FPO# ____¦ Clock ____¦ Vcore _¦ VID ___¦ Tp ¦ Cooling and Misc and Stability Screen
Q820A627 ¦ 4600.7Mhz ¦ 1.440V ¦ 1.2500v ¦ 53 ¦ Custom Water ¦ Asus Maximus X38 ¦ krisbutler ¦ Screen
Q822A435 ¦ 4500.0Mhz ¦ 1.344V ¦ 1.1625V ¦ 59 ¦ Custom Water ¦ Maximus II Formula ¦ Devious ¦ Screen
Q822A435 ¦ 4500.0Mhz ¦ 1.304V ¦ 1.1150V ¦ 66 ¦ Custom Water ¦ XFX 790i Ultra ¦ mremulator ¦ Screen
Q822A435 ¦ 4440.1Mhz ¦ 1.352V ¦ 1.2125V ¦ 60 ¦ TRUE 120 ¦ Maximus II Formula ¦ Vaderat-at ¦ Screen
Q822A435 ¦ 4410.0Mhz ¦ 1.360V ¦ 1.2250V ¦ 66 ¦ OCZ Vendetta 2 ¦ Biostar TPower I45 ¦ Rainmaker ¦ Screen
Q822A438 ¦ 4305.4Mhz ¦ 1.360v ¦ 1.2500V ¦ 73 ¦ Custom Matx water ¦ DFI Lan Party JR P45-T2RS ¦ Bradley8988 ¦ Screen
Q820A670 ¦ 4303.0Mhz ¦ 1.368V ¦ 1.xxxxxV ¦ xx ¦ Air ¦ VTR ¦ Screen
Q820A670 ¦ 4300.0Mhz ¦ 1.344V ¦ 1.2500V ¦ 57 ¦ Scythe Ninja B ¦ Gigabyte P45-DS3P ¦ NS400R ¦ Screen
QA228435 ¦ 4295.9Mhz ¦ 1.256v ¦ 1.1625V ¦ 56 ¦ Air OCZ Vendetta 2 ¦ Biostar TPower I45 ¦ Mike Gunnz ¦ Screen
Standard Rules
8+ hour Prime95/Orthos small FFT, coretemp and CPUZ screens on the same picture. NOT Intelburn
Clockspeed and Vcore readings must be exactly as CPU-Z on load, VID and CPU temp as in Coretemp,
Screenie will be in URL tags and not IMG tags. but please post IMG Tags so the post stands out so i know that i have updating to do on Original Post.
Post instructions:
To make things easier just copy and paste this little form and replace the fields between the [¦]s
(I will bold your username and URL tag)
For examble mine will be:
so it turns out like:
Q820A670 ¦ 4330.3 Mhz ¦ 1.496v ¦ 1.2500v ¦ 81 ¦ OCZ Vendetta 2 ¦ Asus P5Q-E ¦ BornEvil ¦ http://i24.photobucket.com/albums/c45/BornEvil_/433e0.jpg
p.s. not going to include mine as it does not fit into my rules lol, and the CPU is not going back into my Rig for further testing.
THE DATABASE:
Standard Rules
Post instructions:
Code:
FPO# ¦ Clockspeed ¦ Vcore ¦ VID ¦ CPU Temp ¦ Cooling ¦ Motherboard ¦ User name ¦ URL for stability screen
Code:
