...in other news, i have reached 999 posts!
... and still don't have an avatar.
Bad browser? Explain, I use ie7 + ie7pro for 90% of the things and firefox 3 for mainly porn and warez etc... I don't find it any more pleasant to use than ie7, in fact I miss some of the IE7pro features such as rmb draw controls... Only use FF as it's considered safer...
By rmb draw controls i assume you mean Mouse Gestures? Which are available like everything else as an extension for firefox, or built in to Opera.
ie7pro does things for IE that are great, but its still second rate to Opera/firefox. And tbh, if you want to browse "porn and warez" securely, i'd actually sugest IE in protected mode with UAC turned on, or just general common sense really![]()
.The best way of testing this is with the free Virtual PC Image (Windows XP with SP3 + IE 8 beta 2) that you can get from here: http://www.microsoft.com/downloads/...90-958f-4b64-b5f1-73d0a413c8ef&displaylang=en (note: the image expires in Jan 2009)
Its not the best way of testing for Microsoft, because all the hardware IE will think its running on will be stanard. Which defeats the point of an open beta![]()
They aren't beta testing for hardware compatibility, that isn't the purpose of the beta program.
Hardware can cause problems though, specifically in this case network adapter, which would be emulated.
More importantly the VM image will all have the same software configuation, which does defeat the point. On the other hand, you probably shouldn't be testing beta (if that)-quality software on a production machine...
They really couldn't give a toss what configuration people are running, because nobody ever fills in bug reports properly (if at all) with that level of detail in open beta programs.
There is a lot to be said by testing functional areas with a known, baselined configuration.
Internet Explorer is just a failure so I suggest you whip out Opera or firefox.
:-O
How can you deny such sexiness and feature potential as this!
http://robbiekhan.co.uk/root/temp/firefox.jpg
