Made me LOL
Any way im waiting until the firmware update thing has been released and people have commented on its improvements before buying![]()
Thats a sensible conclusion mate.
Made me LOL
Is yours also professionally configured or are you both taking backhanders from hazro?
I think only the 24" has the green snow/lines not the 26"![]()
Hiya Baddass. Haven't spoken to you for a LONG time. Remember all that business with the Xerox monitors a couple of years back! That was funny.
Do you get any banding on gradients?
Then rotate the image in windows picture and fax viewer, you will probably then see some obvious banding of the gradients. is this what you are seeing when you report banding problems?
guys, can you test something for me with these gradients? Save and view the following image in full screen using windows picture and fax viewer (F11 makes it full screen)
http://img178.imageshack.us/img178/1931/gradientimagecoloursfo1.jpg (its a 1920 x 1200 sized image)
what happens if you now zoom in on that image so it's not being squashed onto the screen by windows picture viewer? it should clear the banding and gradients should look smooth again i think
i've just been playing with it on the HZ26Wi as was worred for a minute it was suffering from same vertical banding issue, but i think it might be more to do with the gradient file being viewed! zoom in and tell me if banding still remains....
did you find the same thing as above with zooming in on vertical gradients?
are these all HZ24Wi as well btw?
