Man of Honour
 - 11 Dec 2002
 - Darkest Norfolk
You're stupid.
But yeah, that's the clutch![]()
good point, obviously my brains in backwards this morning...
You're stupid.
Its actually on the brake.
The brake return spring on the pedal has snapped. I've got a new one, but its a right b*****d of a job to replace as you have to dismantle the whole pedal assembly.
The bungee is just a crude, yet effective replacement for that spring until I get round to replacing it.
Well, seeing as I havent got it tied around either my head or my balls, I guess I'll be safe.What if it sprinmgs off and gets you in the eye or sack![]()
 But the show's tomorrow, so needed it up to scratch. So.....
http://www.bajaclub.co.uk/phpBB3/viewtopic.php?f=15&t=3622&hilit=What's with the clamp and the rear screen slats?![]()
Oldschool negative camber. May look a bit daft, but now the wheels dont rub. Oh and it is completely level.![]()
A lot.That is unfortunately positive camber. That's probably going to suffer horribly from jacking under hard cornering. How big a job is the IRS conversion?
 I have added spacers to the rear to widen the track which should hopefully help a bit, plus I put the tyre pressures up to 25psi.Its a 40 year old car, with an 80 year old design, jacked up running on balloons.That camber looks a bit iffy, it still good to drive?
InvG
I had all 4 wheels off the ground last weekend over the jumps.![]()
You tease.![]()
Its difficult to compare it to modern 'normal' cars. Its got a 1584cc engine which produces around 40bhp.Crazy looking thing
What engine has it got? Specs? Out of interest![]()
