Man of Honour
- 17 Oct 2007
Hi dark_shadow, It would be highly advisable to run your system at stock settings for the moment, just until you get your system up and running.
The CPU voltage looks very low for an overclocked Intel Core 2 Duo E6300. If you download Core Temp and install it. Then, take a look at the "VID" option and see what voltage is set for it. This is your default VCore for your E6300.
After you have found it out, go back into the BIOS, set the "CPU Frequency" to "266". "DRAM Frequency" to "667" and "PCI Express Frequency" to "101" (It doesn’t really need to be 110). You can leave the "PCI Clock Synchronization Mode" at "33.33 MHz". Then, "Memory Voltage" to "1.90V" - "2.00V" and "CPU VCore Voltage" to what CoreTemp" - "VID" displayed it as.
Now, as for the "NB VCore", "FSB Termination Voltage", "SB Vcore (SATA, PCI-E)" and finally ICH Chipset Voltage, set them to the lowest value you can, not "Auto" though.
Those settings look absolutely fine.
Now, as far as the timings go, you should be absolutely fine with 4-4-4-12.
After you have run your system at stock settings and you don't experience any more problems with Windows Vista and have the operating system configured the way you like, then overclocking is in order.
The main reason you shouldn't turn it off is so you can run in a standard user account successfully.
My OC settings for anyone interested:
Picture 2
Picture 2
about 2)
If you find it annoying just turn User account control off, it reduces your system security but it saves a bit of time and relieves some stress from having to confirm every new thing... Fire Wizard is one of those guys who reckons you shouldn't turn it off as it reduces the security and he doesn't mind confirming things, but imo it's really rubbish and if you reckon you can keep your pc secured fine then you can just disable it...
