What would happen if the fully accelerated particle beam was fired at a human?
Well as the emergancy system diverts the beam into 5 meters of solid concrete, I'm guessing the technical answer is "a mess".
I imagine the particles would colide with the molecules of your body, ripping them apart leaving a small hole in you, but I'm not sure of the extent of the damage.
And before the conspiricy theorists start thinking "aha, so this was military research into a superweapon" you couldnt really mount a particle accelerator and its required power supply on a tank, and in an atmosphere the particle beam would just collide with molecules in the air before actually hitting it's target.
PK!
