No mate, I got it elsewhere.Did you get that from OCUK Bizarre?
Nah, I read somewhere LLC can have a detrimental effect, can't remember where though.Yeah that's a good un mate. Nice temps as well. Do you enable LLC or not?
Here's the current situation:
I'm HOPING that it's incorrect mobo settings, and the excess CPU volts are somehow compensating for it... Is that possible, or do I really just have a 'dud' overclocker? I mean, I can spend 24 hours solid in Vista at 4.5+ Ghz at less volts than this (albeit not prime stable for long)... Surely a chip that can run at >4.5Ghz at 55 degrees load and 1.392 volts can't need 1.44 volts to be stable at just 4.2 to 4.3Ghz?![]()
I hope no one minds me butting in. But those voltages are way lower than mine.
Why is mine so high?
Think you just got a not so good one like me mate. Can't remember if you posted up the stepping but think you did and it's the same as mine?
I need 1.44v for 4.4Ghz also, any less and it falls over quickly (only primed a few hours before deciding voltage was too high at 1.44v anyway), I'm running at 4.3Ghz with 1.368v, completly stable (10hrs+ on blend and also small ftt)
A good 10 hour Orthos Small FFT run last night/this morning was solid stable at 4.45Ghz (10x445) but needed 1.44 volts (Windows).
Yeah it looks like our chips are brothers, for better or worseA good 10 hour Orthos Small FFT run last night/this morning was solid stable at 4.45Ghz (10x445) but needed 1.44 volts (Windows).
It's blisteringly fast at that rate, with temps around 58 - maxing at 62. Sure the chip will likely give a good couple of years or more even at that rate. But I doubt buyers would want to know this time next year when Nehalem is cheap enough for me to upgrade, when they find out it's been running 12 months at over 1.44v lol
Then again, would I care? I know it's £180 for us early adopters but meh - over a year that's not a lot considering the fun to be had (I don't go pubbing/clubbing = this is my 'recreation' money).
Ace@XS seems to think 1.4v under Windows isn't that big a deal even on 45nm if it's stable and not running hot. I'm currently priming away now at 4295.5Mhz small FFTs. This chip has a tiny FSB 'hole' where it boots anything between 4.2 and 4.6Ghz but refuses point blank to boot at exactly 4300Mhz (it's always just under or just over lol).
So, do I keep 4295 at 1.392v under load in Windows (58 degrees), or do I sod it and go 4400 at 1.44 volts and 62 degrees?![]()
453x9.5 which is just over 4.3Ghz works fine though.bought a few of these hoping to get at least 1 from a good batch
Ended up they are all Q822A435![]()
